Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: Jubilee 3 pt lifting problem
mhb@ufe
12-26-2012 13:10:41
There is a seal between the drive gear and the pump that could be leaking air causing it to loose prime. It is common for the seal to wear a groove in the shaft as well so that would need repair as well as replacing the seal. As for the lifting only in the top 2 inches of travel, you should check the selector lever to make sure that is set for position control and not set to the draft control position.
Mark
Copyright © 1997-2015 Yesterday's Tractor Co.
