Yesterday's Tractor Co.
Shop Now View Cart
Order Ford NAA Parts Online
Re: Jubilee 3 pt lifting problem
12-26-2012 11:38:46
Could have a number of things wrong. Cam follower pin bad can cause that from what I understand as will fluid that is to thick due to temps or incorrect fluid or a seal between the rear end or trans being bad and mixing the thick oil with the thin oil
Jay in WA
12-27-2012 12:18:11
 Re: Jubilee 3 pt lifting problem in reply to old, 12-26-2012 11:38:46
Thanks everyone for the help with this. I did the compressed air test to the hyd dipstick tube and it lifted immediately. So it appears it's loosing prime. I got the O rings from a local Hyd shop and he inspected the tubes and said they were OK. I will do the test of hooking up a tube and looking for flow volume next. I have not opened up the pump to look at it. It works good enough now for snow plowing so I probably won't dig much into it till spring or it quits completely.
