TractorLinks.com
Show Parts for Model:
Re: 641 fuel shut off valve
Will Gumbert
12-24-2012 11:16:59
Depending on what's wrong it might be best to repair the valve you have, if it's the screw-type. This has been discussed on this forum in detail, but it involves replacing the o-ring inside (and the one sealing the valve to the tank). Once you have the valve out, you can carefully chisel off the rivet which allows you to remove the stem and o-ring. Replace the o-ring, then replace the rivet with a self-tapping screw of just the right length to prevent the stem from coming out. A little tricky but definately do-able. -Will
