Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Run with choke on - why?
Larry NCKS
12-24-2012 10:11:05
Either it has a vaccuum leak, or your carb needs cleaned/overauled. The latter is more likely!
Jim Wieringa
12-24-2012 16:01:18
 Re: Run with choke on - why? in reply to Larry NCKS, 12-24-2012 10:11:05
I had the tractor running nice and smooth with the choke on and took a spray bottle with soap and water in it and sprayed every place I could think of and it made no difference in the running. So I guess I can deduct that it is needing a carb kit eh!!
3000OH
12-25-2012 08:22:50
 Re: Run with choke on - why? in reply to Jim Wieringa, 12-24-2012 16:01:18
As for a carb rebuild, some here say that it should only be a genuine CNH kit, not some aftermarket. You may find a seized/corroded accel pump piston.
BTDT before I tossed in the towel on the Holley. Not cheap to do. CNH does not stock replacement Holleys for 2000/3000/4000, only the Zeniths.
Jerry/MT
12-24-2012 17:40:02
What were you hoping to see with soapy water?
Try spraying starting fluid(CAREFULLY!)around the throttle shaft, the carb to intake manifold interface, and the cylinder head to manifold interface. if you heaar the engine speed up, you"ve found your leak. look for vcracks or rust holes in the intake manifold also.
JMOR
12-24-2012 18:08:40
 Re: Run with choke on - why? in reply to Jerry/MT, 12-24-2012 17:40:02
Quoting Removed, click Modern View to seeBubbles inside intake tract? :twisted:
Copyright © 1997-2015 Yesterday's Tractor Co.
