Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Run with choke on - why?
[Return to Forum]
Jim Wieringa
12-24-2012 10:00:17
99.181.142.148
I have a 1966 2000 with Holley carb. Why does it need the choke pulled out to run it's best? Push the choke off and the tractor dies. What do I have to look for? Thanks Jim
[Reply]   [No Email]
DaveH IA
12-25-2012 08:39:27
71.7.102.199
 Re: Run with choke on - why? in reply to Jim Wieringa, 12-24-2012 10:00:17
Also check for good fuel flow from tank-- and I think there is a filter on the fuel pump, Might not be getting fuel to the carb ?? just something else to check
[Reply]  [No Email]
kgrove78
12-25-2012 08:29:50
108.68.74.13
sounds like it needs rebuild i have done several holley carbs for customers and neighbors i use kits from napa or tsc some have been running for several years since. not overly complacated to do. and i use carb clean to look for vac leaks safer than starting fluid with same results. good luck.
[Reply]  [No Email]
TimInd
12-24-2012 21:44:04
75.34.205.207
Another way to find a vacuum leak is with a bottle of propane, not lit obviously. Let a small amount of propane leak out on go over the obvious places where a leak could occur. When the engine speeds up, that's it.
[Reply]  [No Email]
3000OH
12-24-2012 12:46:26
75.93.176.155
Long-known issue. Search the archives for Holley (or its alt spelling). Some swear by 'em, some at 'em. Count me in the latter. Bit the bullet some years ago and bought a Zenith for our '65, zero problems since then. But others like those H-carbs. So do yourself a favor and go back and read both sides of the story.
Have a good holiday.
[Reply]  [No Email]
Larry NCKS
12-24-2012 10:11:05
70.198.16.126
Either it has a vaccuum leak, or your carb needs cleaned/overauled. The latter is more likely!
[Reply]  [No Email]
Jim Wieringa
12-24-2012 16:01:18
99.181.142.148
 Re: Run with choke on - why? in reply to Larry NCKS, 12-24-2012 10:11:05
I had the tractor running nice and smooth with the choke on and took a spray bottle with soap and water in it and sprayed every place I could think of and it made no difference in the running. So I guess I can deduct that it is needing a carb kit eh!!
[Reply]  [No Email]
3000OH
12-25-2012 08:22:50
75.93.176.155
 Re: Run with choke on - why? in reply to Jim Wieringa, 12-24-2012 16:01:18
As for a carb rebuild, some here say that it should only be a genuine CNH kit, not some aftermarket. You may find a seized/corroded accel pump piston.
BTDT before I tossed in the towel on the Holley. Not cheap to do. CNH does not stock replacement Holleys for 2000/3000/4000, only the Zeniths.
[Reply]  [No Email]
Jerry/MT
12-24-2012 17:40:02
206.183.116.145
What were you hoping to see with soapy water?
Try spraying starting fluid(CAREFULLY!)around the throttle shaft, the carb to intake manifold interface, and the cylinder head to manifold interface. if you heaar the engine speed up, you"ve found your leak. look for vcracks or rust holes in the intake manifold also.
[Reply]  [No Email]
JMOR
12-24-2012 18:08:40
72.181.173.171
 Re: Run with choke on - why? in reply to Jerry/MT, 12-24-2012 17:40:02
Quoting Removed, click Modern View to seeBubbles inside intake tract? :twisted:
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
