Identifying 3-cyl tractors
dzus
Looking in my 3-cylinder parts book. I know 2100 &
3100 are the common utility tractors. What is a
2110? What is a 4110? What is a 4140? the parts book
doesn't say what these models are. Thanks!
2110 is a ford 2000 LCG tractor. Low Center of Gravity used mainly for mowing. 4110 is same LCG style on a 4000 model.
Here's mine
John
A side note on that is that the 4110 (4000LCG) uses the same rear axle as the 3000, not the double reduction axle with wet disk brakes that other 4000 variants use.
2110 was the low center of gravity version of the 3 cylinder 2000 series.
4110 was the low center of gravity version of the 3 cylinder 4000 series.
4140 was the 3 cylinder 4000SU.
4140x was the heavy industrial version of the prior 4 cylinder 4000 series. The last digit varied depending on trans/PTO options.
