TractorLinks.com
Show Parts for Model:
Re: Electronic Ignitor
JMOR
12-22-2012 06:50:28
So much for "modules won't work at reduced voltage". If you didn't know, maybe it didn't know either & the old saw, 'if you don't know it, it won't hurt" applies?
soundguy
12-22-2012 18:09:55
 Re: Electronic Ignitor in reply to JMOR, 12-22-2012 06:50:28
I bet you those 12v ones have a wider input voltage range than one may think.
say they are using 5v logic.( for arguments sake ) on a 6v system, that doesn't leave much play. on a 12v system.. they are golden. stick in a 7805 and go. input v can be 25v :) ( just for arguments sake.. I know they are not using a 7805, etc.. but same would apply for whatever device methodology to get 4a supply current. ( mind you.. with thermally protected 7805, , you could parallel 5 of them.. :) ;) )
JMOR
12-22-2012 19:42:59
 Re: Electronic Ignitor in reply to soundguy, 12-22-2012 18:09:55
Quoting Removed, click Modern View to seeNot than I may think! I expect that all N's, pos gnd, neg gnd, 6v, 12v, front mount, side mount are all covered by two modules. Further I would not expect to find a voltage regulator in these simple modules. :lol:
soundguy
12-24-2012 12:08:31
 Re: Electronic Ignitor in reply to JMOR, 12-22-2012 19:42:59
I wasn't talking about you.. :) and no.. i don't think they have a monolithic vr module in there specifically either.. plenty of ways to handle wide range of inputs on chip.. etc.
I would have guessed 4 modules.
2 front, 2 side. one for positing gorund, one for negative ground each.
then again.. I've never seen the front mount module.. is it physically near same size as side?.
JMOR
12-24-2012 14:11:06
 Re: Electronic Ignitor in reply to soundguy, 12-24-2012 12:08:31
Quoting Removed, click Modern View to seeDifferent breaker plates & magnet ring in kit, but modules look same except wire colors for POS/NEG.
soundguy
12-25-2012 09:28:34
 Re: Electronic Ignitor in reply to JMOR, 12-24-2012 14:11:06
yep, I new the BP would be different. I guess if it's small enough to use trhe same mao no reason not to.
I believe the module in my farmall C would drop into one of my fords.. :) module anyway..
