Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4500 Parts Online
Re: 4500 TLB - no reverse
JF in CT
12-21-2012 12:14:30
This is odd. Forward but no reverse. Mine does this (no F or R) often when the fluid is cold. I usually hold slight pressure on the lever while curling the front bucket. Usually goes in just before the engine wants to stall. No issue after it warms up. Check the linkage as it goes into the bell housing. Mine was held by a cross bolt but there was no slot in the arm to tighten it on the rod. Added a slot and it has been tight ever since. Just a guess.
Jim
PHC
12-21-2012 13:26:08
 Re: 4500 TLB - no reverse in reply to JF in CT, 12-21-2012 12:14:30
Thanks for the reply Jim.I did check the linkage at the bellhousing & disconnected the yoke pin & shifted the tractor there.Same result: F&N no reverse.It did this once a few wks ago.I changed the oil & filter thinking a contamination problem.Started the tractor,let it run for a few minutes,re-checked oil level & the transmission shifted fine.Used it for a few hrs,no problems.Parked it inside for 2wks- no reverse!
