Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 4500 TLB - no reverse
[Return to Forum]
PHC
12-21-2012 06:41:44
67.240.179.63
1972 4500 3cyl diesel 4spd power reversing transmission TLB with a cab.Tractor will not go in reverse.Did this once before,then was fine for a few wks.New 134D & filter.With idle slow,tractor shifts into forward & neutral fine.Guessing the blocker valve is sticking.Removing the cab,fuel tank & steering column is alot of work.Anything I can try before I get into this? Thank You.
[Reply]   [No Email]
Fritz Maurer
12-21-2012 19:43:42
216.137.138.146
 Re: 4500 TLB - no reverse in reply to PHC, 12-21-2012 06:41:44
Pull the engine and overhaul the direction clutches.
[Reply]  [No Email]
JF in CT
12-21-2012 12:14:30
71.88.46.81
This is odd. Forward but no reverse. Mine does this (no F or R) often when the fluid is cold. I usually hold slight pressure on the lever while curling the front bucket. Usually goes in just before the engine wants to stall. No issue after it warms up. Check the linkage as it goes into the bell housing. Mine was held by a cross bolt but there was no slot in the arm to tighten it on the rod. Added a slot and it has been tight ever since. Just a guess.
Jim
[Reply]  [No Email]
PHC
12-21-2012 13:26:08
67.240.179.63
 Re: 4500 TLB - no reverse in reply to JF in CT, 12-21-2012 12:14:30
Thanks for the reply Jim.I did check the linkage at the bellhousing & disconnected the yoke pin & shifted the tractor there.Same result: F&N no reverse.It did this once a few wks ago.I changed the oil & filter thinking a contamination problem.Started the tractor,let it run for a few minutes,re-checked oil level & the transmission shifted fine.Used it for a few hrs,no problems.Parked it inside for 2wks- no reverse!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
