Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 7700 Fuel Issue
[Return to Forum]
Daniel Wieringa
12-19-2012 17:19:10
50.105.78.162
I will try to cover everything leading up to my problems. I had the injection pump rebuilt summer of 2011 at Diesel Injection Service in Grand Rapids. I made sure there was oil in it when I put it back on. I also put on a new fuel pump (the one with the hand crank thing).I have had it sitting by the road all summer with a for sale sign on it because I don"t need it anymore. I ran it every once in a while to mow the grass around it and keep the battery charged. The last time I tried to move it, it didn"t want to start so I bled the lines, there was fuel, so I changed the fuel filter because I figured it might have plugged up sitting during the summer. I did get it running but it would run for a few minutes and peter out and die. If you had it sitting in the driveway it would run fine all the way to full throttle for as long as you wanted. As soon as I got driving around for a minute or two it would peter out and die, like it was getting air from somewhere. I went to the auto parts store and got some hose and pipe adapters and went around the hard line that runs along the engine block, it had been brazed once, but it looked fine. It continued to do peter out after a minute driving around like it did before. So I took off the bottom tank (the hose clamp at the suction line may have been loose?) and found that the filter screen wasn"t there so I got the draincock with the screen from the Ford dealer since that"s the way it has to be bought now. I put the screen on with some Seal All because it is supposed to be fuel resistant. I got it all put back together and got the tractor running. It will run for a little bit, then starts to bog down, not die most of the time though. It acts like it is burning through the fuel in the filter and then not being able to suck enough through the screen? I don"t have much if any fuel in the top tank at the moment. I"m not sure if the other problem is gone because this one seems to occur faster and then you can"t get going long enough. I would appreciate any help! Thanks!
[Reply]   [No Email]
showcrop
12-21-2012 07:42:00
75.67.231.80
Re: 7700 Fuel Issue in reply to Daniel Wieringa, 12-19-2012 17:19:10
I had the same problem twice with my 9000. First time it was fuel line blocked with crud from the tank, where the return line tees in. Second time it was two in one. First I had put a new gasket on top of the filters without removing the old, which blocked the filter outlets. Second in trouble shooting I damaged the threads at the suction side of the lift pump so it was sucking air.
  [Reply]  [No Email]
RodInNS
12-20-2012 20:33:05
216.118.158.123
I'd pull the intake line off the lift pump and blow some compressed air back through that line to the tank. That may dislodge whatever is restricting it. You could also temporarly plumb a line into a can of fuel to the lift pump and see if it will run like that.
You could have a bad lift pump... or a restricted line to the bottom tank, an air leak, a plugged vent line from the bottom tank or even have the lift and vent lines reversed...
I doubt it's a very serious problem.
Rod
  [Reply]  [No Email]
Jerry/MT
12-20-2012 17:39:41
206.183.116.145
Did you see ant crud in the tank when you pulled the tank valve out? Something maybe blocking the outlet and restricting the fuel flow. Also check the lines to make sure they aren"t restricted. If you have a lift pump in the fuel circuit, make sure it"s wrking properly. Some have filters on them so check for that also. make sure all the lines are tight so you can"t suck air.
  [Reply]  [No Email]
Tx Jim
12-20-2012 04:00:42
67.142.163.24
Have you checked for good fuel.flow out of tank?? It's possible tank is not venting so a suction is formed. Try running engine with fuel cap off.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
