| Ford Tractors Discussion Forum |
Topic: Re: Float on remote?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Fritz Maurer
12-19-2012 05:12:52
216.137.138.146
Float is automatic on single-acting hydraulic systems by virtue of simply letting the oil out of the cylinder. Float on double-acting systems connects both ends of the cylinder so the oil can flow to either end of the cylinder as the rod moves in and out. This is accomplished by a third position on the spool that allows free flow of oil to either end of the cylinder and free bypass flow from the pump. In your case, it appears that you have a regular two-position spool that locks the cylinder in neutral, and you obtain float by opening the needle valve. One full turn should be plenty. If you only have one line, (gravity-drop, single-acting) opening the needle valve will have no effect. (there's no place for the oil to go, the other port is plugged) |
[Reply] [No Email] | |
| Larry NCKS
12-19-2012 05:43:10
70.195.0.113
Re: Float on remote? in reply to Fritz Maurer, 12-19-2012 05:12:52
| I don't believe you can open that valve too far. I don't think it will screw out of the body with removing some sort of keeper, either a set screw in the side or a snap ring.
As to Fritz' description, I don't entirely agree. If you don't open that valve for a single acting (one hose) cylinder, the hydraulic system will be putting full pressure against that 2nd port with nowhere for it to go except relief valve.
As to the front plug, I'm not sure what that might be unless it's an alternate for one of the other two. |
| Fritz Maurer
12-19-2012 17:18:11
216.137.138.146
Re: Float on remote? in reply to Larry NCKS, 12-19-2012 05:43:10
| Larry, I think you may be right. I'm wondering, how does the oil get out of the cylinder through that needle valve, combined with the flow from the pump? Is it possible there is a float position on the spool, and that knob is actually a FLOW control? |
| gunny2
12-19-2012 18:55:36
174.124.4.3
Re: Float on remote? in reply to Fritz Maurer, 12-19-2012 17:18:11
| This valve has blue paint under red. Wondering if it possibley came off a thousnd series. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
