| Ford Tractors Discussion Forum |
Topic: Serial Number Location on a 3 cyl. 2000
[Return to Forum]
| Author |
[Modern View]
| Jim Wieringa
12-17-2012 14:43:46
99.181.142.148
Where is the location on a 2000 3 cylinder for the serial number? |
| rd 2n in mo
12-18-2012 10:44:14
76.214.48.28
Re: Serial Number Location on a 3 cyl. 2000 in reply to Jim Wieringa, 12-17-2012 14:43:46
|   look here |
| Jim Wieringa
12-18-2012 14:40:56
99.181.142.148
Re: Serial Number Location on a 3 cyl. 2000 in reply to rd 2n in mo, 12-18-2012 10:44:14
| Thank you all, it has been very helpful. I now have the numbers I need to know what I have.. |
| Sean in PA
12-17-2012 16:45:49
71.224.102.32
| It's stamped into the flat spot that faces upwards on the transmission bell housing just toward the rear of the tractor from the starter. There should be 3 numbers stamped into that flat spot. The first number should be the model number (not 2000, but a coded model number that says exactly which engine, PTO and transmission options the tractor had). The second number should be the Unit Number, or production code, which will tell you exactly what day the tractor rolled off the assembly line. The third number is the serial number and should start with a letter, either A, B or C, depending on which factory it was assembled at, followed by a 6 digit number.
If you're lucky, those same numbers might still be on a foil sticker on the under side of the right side hood panel as well. If that sticker's still there it will also have the production codes for the engine, transmission, hydraulic lift and hydraulic pump assemblies as well. |
| Mike Groom
12-17-2012 15:52:07
199.36.210.202
| It's located on the flat horizontal portion of the casting on the right side of the engine where it joins the transmission,it should be a milled surface with the # on it. Hope this helps. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
