Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 4000 Parts Online
Re: 4000 fuel tank gas line
12-17-2012 06:15:41
It sounds just like the line on my 901 which is how they were built. The 800 through the 4 cyl. 4000 were known to get hot and boil gas in the tank when working hard in hot weather. E-85 has a lower boiling point, so the proximity of the line to the exhaust manifold should be a consideration for you, if you are planning to work the tractor hard. I secured some tinfoil around mine to shield from the heat. If you are planning to pick-up a new original tube you may be in for a little shock. I recently cut the deteriorated rubber section out of mine and replaced it with high heat silicone rubber tubing. Many on this forum replace the original with 5/16 brake line.
