TractorLinks.com
Order Ford NAA Parts Online
Re: jubilee hydraulic pump question
JMOR
12-16-2012 15:40:49
Quoting Removed, click Modern View to seeUnless you have a pump of some unknown type that is neither of those that came on the Jubilee/NAA, then it sounds like you have a piston pump & not the vane pump. If that is the case, then the plug you mention is on the pump output. OK to take it out and use a good sealant on threads, but teflon tape is not recommended, at least by many, since it is so easy to introduce slivers of it into the hydraulic flow circuits, where it can cause malfunctions.
The plug in question is probably where the clear hose is connected on this piston pump.
ericlb
12-16-2012 16:19:08
 Re: jubilee hydraulic pump question in reply to JMOR, 12-16-2012 15:40:49
thanks guys the clear hose here is the place im talking about on mine and this is the same pump on this tractor i have, so im confused now as to what the original is, as these arnt what is pictured inthe owners manuel i have for this tractor, is this pump the original, or is this the replacement style? i'll use something else other than Teflon to reseal, the plug is tight now, already tried to tighten that
soundguy
12-17-2012 11:00:09
 Re: jubilee hydraulic pump question in reply to ericlb, 12-16-2012 16:19:08
it's a cheap tapered plug.. get a new one. i reccomend a brass square headed one.. that and some gasola, or harveys thread dope. a CI plug will work as well.
that is a repalcement piston pump.. it is cylindrical.. the oem pump was a squareish vane pump.
