how would you go about removing some junk floating around in the last half inch of fuel left in there? The tank is nice and shiney inside, no rust etc, it just has some small bits of junk floating around in the fuel thats left in the bottom. I'd like to get it cleaned out and filled back up and running before the cold sets in.
I was thinking of putting a gallon or so in it and siphoning it out through the fill hole and see if I could move the siphon tube around enough and suck the junk out, rinse repeat, etc.
Also, there isnt any filter on the petcock that screws up into the bottom of the tank, I was thinking that if there was one there, it would probably clog up the petcock, good?, bad?, ideas?
Any better ideas floating around out there?
Thank You
Thank You
