| Ford Tractors Discussion Forum |
Topic: 2000 3cyl. gas problem
[Return to Forum]
| Author |
[Modern View]
| THEkyroastnear
12-15-2012 10:32:14
12.74.88.30
just installed a carb. kit (zenith) tractor was running but ran rich and would not adjust out. after kit tractor started, ran just a few minutes and quit has not started since .float is working as it should getting fire has fair compression 68-72 but acts as if tries to flood self out will not even try to hit, tried to pull it with no luck either would not even try anybody got any ideas i am stumped. also need to know plug gap,had it wrote down but must have lost it. thanks |
[Reply] [No Email] | |
| Hobo,NC
12-16-2012 06:43:14
75.89.255.106
Re: 2000 3cyl. gas problem in reply to THEkyroastnear, 12-15-2012 10:32:14
| Low compression is you main issue :!: |
| THEkyroastnear
12-16-2012 06:22:25
12.74.88.27
| i verfied my spark the same way your pic. shows and black exhaust told me the carb was too rich. i will try some things mentioned on this site, it will be most likely the next weekend before i post any thing else |
| Ultradog MN
12-15-2012 16:53:58
184.100.109.75
| The tractor would never have run on 70 psi compression. Never. Redo your test as it can not be accurate. All plugs out, fresh battery and WOT. I don't like hunches. Tell us more how you verified the spark. Old plugs might be fouled etc. You can burn them off in the kitchen stove or use a propane torch. You could have so much fuel in it too that even new plugs might not light it off. I say go back to your spark. Verify and post back.
| showcrop
12-15-2012 16:35:15
75.67.231.80
| You are still holding back a lot. How did you know that it was running rich and what did you do to try to "adjust it out" |
| THEkyroastnear
12-15-2012 14:29:47
12.74.88.98
| there is not really much to tell about the tractor, i have owned it about 2 years it has always started good and worked in a satisfactory way, although i have always known it could stand a kit. what caused me to take it apart was late this summer it developed a gas leak at the carb or so i thought come to find out a fitting was cracked in fuel line so while i had it off thought would be a good time for that kit. i didnt know it would run into more problems. i will check on everything folks told me about and i didnt know what kind of compression it should have had.this my first ford i am more familiar with old Ms or Hs.thanks for the input |
| soundguy
12-15-2012 13:57:03
107.41.91.157
| 68 would be dismal on a N.. on a 3 cyl, it's probably like HALF... |
| Jerry/MT
12-15-2012 12:29:53
206.183.116.145
| That"s pretty sorry compression (unless your at 14000 ft elevation)! The min allowable is probably ~ 90 psi at sea level. Make sure you don"t have a sticking or burnt valves. |
| old
12-15-2012 10:44:48
209.86.226.32
| Plug gap and point gap if I remember right should both be about the same at 0.025. As for compression that is very poor compression. even the old 8N needs at a min. of 90PSI to run well and that 2000 should have a good bit more then that. Tell us the whole story behind this old machine and maybe we can help. With what you have said I would first off get a good blue/white spark that will jump a 1/4 inch gap. Then I would put say a 1/4 cup ATF in the cylinders and then open the carb back up and make sure the float is set correctly and that the needles seat is tight and that the needle is seating as it should |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
