TractorLinks.com
Show Parts for Model:
Re: 6 Volt generator warning light for 641 Ford
showcrop
12-15-2012 07:03:15
JMOR, let me tell ya that bulb is worth every penny of the $12.50 to me. It actually is not just the bulb, it is the bezel, lens housing in one assembly. It is only on the X01 series to the best of my knowledge. The original one on my 901 that I recently finished was not capable of mounting in the hole, receiving a bulb or wire, so it needed to be replaced. Actually I don't believe that you can remove the bulb. Even if it could it would have looked like cr^p on my tractor.
Keith Williams
12-15-2012 17:25:33
 Re: 6 Volt generator warning light for 641 Ford in reply to showcrop, 12-15-2012 07:03:15
Showcrop,
That light was also used on the 4 cyl 2/4000. I added the voltmeter.
Keith
Will Gumbert
12-15-2012 13:13:40
showcrop, if I could ask an unrelated question, it looks like you put new pressure and return lines on the power steering. The return line is just a hose, but the pressure line is an assembly - is it only available from CNH or is there another supplier? Mine is cracked (the hose that is). -Will
showcrop
12-15-2012 16:24:39
 Re: 6 Volt generator warning light for 641 Ford in reply to Will Gumbert, 12-15-2012 13:13:40
Will, that hose is original, just cleaned and painted. CNH shows it as still available, but I expect that it will be over $100.00. I haven't seen any one else offer it.
Will Gumbert
12-15-2012 17:02:15
 Re: 6 Volt generator warning light for 641 Ford in reply to showcrop, 12-15-2012 16:24:39
OK, thanks. Nice job on the PS lines (and everything else!). I cringe everytime I ask the guy at my local CNH dealer for a price. For some things, they are about the only source. I might be able to get a specialty shop to rebuild the line for me. Thanks -
Will
JMOR
12-15-2012 07:09:48
Quoting Removed, click Modern View to seeGot it. :) For a looker like that, it was cheap at twice the price!
