OliverMan1855
Took my head off lapped the valves replaced a bent push rod and new air cleaner and new head bolts. all of this made it start a bit easier then before and is deffenantly throatier! But Im thinking I have a bad set of injectors. Smokes a LOT of white and black cold started and doesnt want to rev or run smooth till its warmed up even at 60 degrees. Acts the same down to 30. Starts up in the summer easy but the problem is still noticable when you rev it. I got a tw35 injector pump on stock injectors. Thinking there leaking down because when its hot it still smokes a little white at idol. Not compression because you need a pry bar on the alternator to turn it over and hisses from inside the motor. Great compression. going to due 4x.22 injectors.
