TractorLinks.com
Show Parts for Model:
Re: 981 SOS
TONY JACOBS
12-14-2012 06:57:12
Hello Joe , R1 and 9th gear are the tell tale gears of a Over Running Clutch going bad not 5th or 6th . Thanks Tony
Joe(TX)
12-14-2012 17:17:17
 Re: 981 SOS in reply to TONY JACOBS, 12-14-2012 06:57:12
Tony
Go back and look at the book again
TONY JACOBS
12-14-2012 20:30:18
 Re: 981 SOS in reply to Joe(TX), 12-14-2012 17:17:17
Hello Joe , The Book was written in 1959 when the SOS first came out , the problems were on brand new UNWORN transmissions , now when you compound 50 plus years of wear on them EVERYTHING CHANGES the book only becomes a GUIDE it is no longer the gospel . By the time it shows up in 5th or 6th it no longer even moves in other gears . As I said a high hour worn ORC will show up in R1 first then 9th 99% of the time when cold , then work when hot . After that it only goes downhill and get worse . Thanks Tony
Larry NCKS
12-14-2012 18:06:36
Joe - I believe what Tony is saying is that ORC problems will show up the earliest in R1 & 9. He's not saying it won't show in 5th & 6th as well.
I also believe that Tony has had enough experience on SOS and other Ford stuff that I dare not dispute his word on the subject.
Joe(TX)
12-18-2012 18:55:32
 Re: 981 SOS in reply to Larry NCKS, 12-14-2012 18:06:36
That's not the way it was stated.
Larry NCKS
12-19-2012 05:35:26
 Re: 981 SOS in reply to Joe(TX), 12-18-2012 18:55:32
I'm assuming this is aimed as my reply to your previous comment on R1 & 9 being telltale ratios on the ORC.
If so, then I'm wondering what you think the word "telltale" means? I'm interpreting it to mean first indication. Therefore it was stated correctly.
TONY JACOBS
12-14-2012 20:23:07
Hello Larry , Thank you for the help and your knowledge . Thanks Tony
Larry NCKS
12-14-2012 20:50:24
 Re: 981 SOS in reply to TONY JACOBS, 12-14-2012 20:23:07
Not that you need any help, Tony, but you're most welcome!
Dave Warden
12-14-2012 15:07:22
Tony,What are you talking on the clutch being fixed. Havent looked to see ifin you can even buy thge clutch. Thanks Dave
TONY JACOBS
12-14-2012 20:21:09
 Re: 981 SOS in reply to Dave Warden, 12-14-2012 15:07:22
Hello Dave , The Over Running Clutch Kit from Ford has been discontinued for many years now and guys like myself who still work on them have bought just about every one left in the US and Canada and all of the Discontinued Warehouses , I only knew of one left in Canada a couple of years ago for $1100 just about what Ford would have sold it for new . Currently I am working on building a new heavier duty Clutch set up to completely replace the Ford unit . The first two experimental units did not work out so well so hopefully number three will be the charm . Thanks Tony
Micah M
12-15-2012 18:03:57
 Re: 981 SOS in reply to TONY JACOBS, 12-14-2012 20:21:09
If you get your clutch to work I am interested. I have a 981 that the clutch is out on and would like to fix it. May need one for the 881 as well.
TONY JACOBS
12-15-2012 22:46:55
 Re: 981 SOS in reply to Micah M, 12-15-2012 18:03:57
Hello Micah , I know I can get it to work but I am trying to make work better , longer , and stronger than the original did with out breaking the bank so that it will be a worth doing for resale units that I rebuild or someone like your self who needs one for his own tractors . Hopefully over the winter I will get a chance to finish one up and try it out for the spring time . Thanks Tony
