TractorLinks.com
Show Parts for Model:
Re: FordFarmer
showcrop
12-13-2012 16:35:17
Hey Chris, don't forget that those row crop 4000s and 5000s can be easily converted from wide to narrow.
Zack(NC)
12-21-2012 05:50:04
 Re: FordFarmer in reply to showcrop, 12-13-2012 16:35:17
They are easy to change yes, but you have to have the mounting plate to the pedestol before you can use the single front or tricycle front on the 5200 & they arn"t cheap to buy unless you get lucky, You can actullay have 4 different styles of fronts for the 5200, the single wheel, tricycle, wide front set out or wide front set back for closer turning radius, we"ve had our 5200 all 4 ways before but it"s currently "set back" wide front right now. There"s a old Ford dealer here in NC that has a brand new one for $1000 Zack
soundguy
12-13-2012 16:50:08
is it as simple as a pedistal change?
are the pedistals the same among them?
the NF later models are just so rare around here.. never see them.. an odd 6000 now and then.. etc..
showcrop
12-14-2012 07:49:48
 Re: FordFarmer in reply to soundguy, 12-13-2012 16:50:08
Knowing that you are not a purist, a Farmall pedistal nearly bolts right up.
soundguy
12-14-2012 15:07:11
 Re: FordFarmer in reply to showcrop, 12-14-2012 07:49:48
hey.. CNH Case / New holland.
that's close right? :)
Shetland Sheepdog
12-14-2012 08:39:23
Colin, is that what you have on your 9000?
showcrop
12-14-2012 14:44:32
 Re: FordFarmer in reply to Shetland Sheepdog, 12-14-2012 08:39:23
How did you guess? LOL
Ultradog MN
12-14-2012 17:13:43
 Re: FordFarmer in reply to showcrop, 12-14-2012 14:44:32
Got pics of that changeover?
Or can you take some and show us?
I like a bit of farmerizing - resourceful.
Fordfarmer
12-14-2012 06:17:07
I believe it is that simple. The 4200 has it's own wide front axle, but the 5200 and 7200 (and '76 66/7600 RC's) share the same wide axles. Don't know without checking p/n's, but I -think- they all use the same NF pedistal. May even be the same as the prior RC's. Any time you get a '65-up RC, it will be a flat deck.
Zack(NC)
12-21-2012 05:56:23
 Re: FordFarmer in reply to Fordfarmer, 12-14-2012 06:17:07
I was telling showcrop that they are easy to change but the 5200's require a bracket that bolts to the pedestol, then you can bolt up the single front or a tricycle front to the 5200, we have had our 5200 all 4 ways before single, tricycle, & wide front "set out" & wide front "set back" for shorter turning radius, the 4200's do not require the plate, the fronts you choose will bolt right up! Zack
showcrop
12-21-2012 07:15:33
 Re: FordFarmer in reply to Zack(NC), 12-21-2012 05:56:23
Zack, I just checked out the CNH parts page and I see a spacer there, but I don't see a need for it. I just bolted the Farmall pedestal up to the plate on the bottom of the motor of my 9000. Perhaps the plate on the 5000 is recessed? in which case a spacer could be easily be made to afford the necessary clearance.
