Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: FordFarmer
[Show Entire Topic]  [Return to Forum]
soundguy
12-13-2012 15:05:37
173.107.60.133
don't think it isn't tempting... if a similar one popped for sale a lil farther south.. it might follow me home..
for instance.. a gasser 5000 NF.. I might have to drive for that one.. :)
[Reply]   [No Email]
TONY JACOBS
12-14-2012 06:51:15
205.188.116.9
 Re: FordFarmer in reply to soundguy, 12-13-2012 15:05:37
Hello Chris , I used to know where there was TWO single wheel fronts for the 5000 , if you are interested I can check to see if they are still there then you would not be limited to just a narrow front , you could grab a wide front and convert it yourself . Thanks Tony
[Reply]  [No Email]
soundguy
12-14-2012 15:14:19
107.41.134.174
 Re: FordFarmer in reply to TONY JACOBS, 12-14-2012 06:51:15
if you have the # laying around I'd surely take it.
5200 are somewhat common here. I know where 2 flat platfrom are right now.. wide front of course..
[Reply]  [No Email]
TONY JACOBS
12-14-2012 20:34:21
64.12.116.9
 Re: FordFarmer in reply to soundguy, 12-14-2012 15:14:19
Hello Chris , I will call him and see if he still has them as I need to speak with him about some other parts , if he does I will get his number to you and you guys can deal direct . Thanks Tony
[Reply]  [No Email]
soundguy
12-14-2012 21:14:29
184.4.146.28
 Re: FordFarmer in reply to TONY JACOBS, 12-14-2012 20:34:21
appreciate it...
[Reply]  [No Email]
TONY JACOBS
12-15-2012 22:35:43
64.12.116.9
 Re: FordFarmer in reply to soundguy, 12-14-2012 21:14:29
Hello Chris , Both Single front / Narrow front have been sold . I asked him to let me know if he locates anything else in either single or double narrow for the 5000 , 7000 , 8000 tractors . Thanks Tony
[Reply]  [No Email]
soundguy
12-17-2012 05:37:56
107.41.11.98
 Re: FordFarmer in reply to TONY JACOBS, 12-15-2012 22:35:43
appreciate ya looking.
thanks
[Reply]  [No Email]
showcrop
12-13-2012 16:35:17
75.67.231.80
Hey Chris, don't forget that those row crop 4000s and 5000s can be easily converted from wide to narrow.
[Reply]  [No Email]
Zack(NC)
12-21-2012 05:50:04
174.98.94.96
 Re: FordFarmer in reply to showcrop, 12-13-2012 16:35:17
They are easy to change yes, but you have to have the mounting plate to the pedestol before you can use the single front or tricycle front on the 5200 & they arn"t cheap to buy unless you get lucky, You can actullay have 4 different styles of fronts for the 5200, the single wheel, tricycle, wide front set out or wide front set back for closer turning radius, we"ve had our 5200 all 4 ways before but it"s currently "set back" wide front right now. There"s a old Ford dealer here in NC that has a brand new one for $1000 Zack
[Reply]  [No Email]
soundguy
12-13-2012 16:50:08
173.107.60.133
is it as simple as a pedistal change?
are the pedistals the same among them?
the NF later models are just so rare around here.. never see them.. an odd 6000 now and then.. etc..
[Reply]  [No Email]
showcrop
12-14-2012 07:49:48
75.67.231.80
 Re: FordFarmer in reply to soundguy, 12-13-2012 16:50:08
Knowing that you are not a purist, a Farmall pedistal nearly bolts right up.
[Reply]  [No Email]
soundguy
12-14-2012 15:07:11
107.41.134.174
 Re: FordFarmer in reply to showcrop, 12-14-2012 07:49:48
hey.. CNH Case / New holland.
that's close right? :)
[Reply]  [No Email]
Shetland Sheepdog
12-14-2012 08:39:23
72.71.219.61
Colin, is that what you have on your 9000?
[Reply]  [No Email]
showcrop
12-14-2012 14:44:32
75.67.231.80
 Re: FordFarmer in reply to Shetland Sheepdog, 12-14-2012 08:39:23
How did you guess? LOL
[Reply]  [No Email]
Ultradog MN
12-14-2012 17:13:43
184.100.109.75
 Re: FordFarmer in reply to showcrop, 12-14-2012 14:44:32
Got pics of that changeover?
Or can you take some and show us?
I like a bit of farmerizing - resourceful.
[Reply]  [No Email]
Fordfarmer
12-14-2012 06:17:07
184.158.71.223
I believe it is that simple. The 4200 has it's own wide front axle, but the 5200 and 7200 (and '76 66/7600 RC's) share the same wide axles. Don't know without checking p/n's, but I -think- they all use the same NF pedistal. May even be the same as the prior RC's.
Any time you get a '65-up RC, it will be a flat deck.
[Reply]  [No Email]
Zack(NC)
12-21-2012 05:56:23
174.98.94.96
 Re: FordFarmer in reply to Fordfarmer, 12-14-2012 06:17:07
I was telling showcrop that they are easy to change but the 5200's require a bracket that bolts to the pedestol, then you can bolt up the single front or a tricycle front to the 5200, we have had our 5200 all 4 ways before single, tricycle, & wide front "set out" & wide front "set back" for shorter turning radius, the 4200's do not require the plate, the fronts you choose will bolt right up! Zack
[Reply]  [No Email]
showcrop
12-21-2012 07:15:33
75.67.231.80
 Re: FordFarmer in reply to Zack(NC), 12-21-2012 05:56:23
Zack, I just checked out the CNH parts page and I see a spacer there, but I don't see a need for it. I just bolted the Farmall pedestal up to the plate on the bottom of the motor of my 9000. Perhaps the plate on the 5000 is recessed? in which case a spacer could be easily be made to afford the necessary clearance.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
