Ultradog MN
- Location
- Twin Cities
(quoted from post at 16:05:37 12/13/12) don't think it isn't tempting... if a similar one popped for sale a lil farther south.. it might follow me home..
for instance.. a gasser 5000 NF.. I might have to drive for that one..
(quoted from post at 17:50:08 12/13/12) is it as simple as a pedistal change?
are the pedistals the same among them?
the NF later models are just so rare around here.. never see them.. an odd 6000 now and then.. etc..
(quoted from post at 09:39:23 12/14/12) Colin, is that what you have on your 9000?
(quoted from post at 06:56:23 12/21/12) I was telling showcrop that they are easy to change but the 5200's require a bracket that bolts to the pedestol, then you can bolt up the single front or a tricycle front to the 5200, we have had our 5200 all 4 ways before single, tricycle, & wide front "set out" & wide front "set back" for shorter turning radius, the 4200's do not require the plate, the fronts you choose will bolt right up! Zack
