Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: NAA electric question..
Royse
12-09-2012 19:27:57
You should not have continuity through your push button unless it is pressed.
Replacing it requires removing the top cover of your transmission because
there is a nut on the bottom of the switch that is held in place by a locking plate.
However, if it worked before, I would double check the continuity tests.
The solenoid needs to be a three terminal type made for tractors.
One big wire to the starter, one big wire from the battery.
On the big wire from the battery is also a small wire to your terminal.
Small terminal on the solenoid comes from the push button.
No ground required for the case.
It will not work if you have the starter side and battery side reversed.
You can tell which side goes to the battery by measuring continuity between it and the little post.
Starter side should not have continuity, battery side will have a low resistance.
Copyright © 1997-2015 Yesterday's Tractor Co.
