NAA 6 volt electrical questions.
I have a starting problem with a NAA I just picked up.
These might be dumb questions, but I need to ask, I struggle with + ground.
Does the starter solenoid need to make good contact with the chassis and which terminal is battery and which is starter?
My son replaced it after someone said it was bad, now it won't do anything.
I had 4 cables, 1 batt, 1 starter, 1 switch and I guess 1 to amp or the terminal block?
Also, on the starter button, it seems I have continuity thru it regardless if it's pressed or not, so I'm thinking I need a new starter switch for sure.
