TractorLinks.com
Order Ford 640 Parts Online
Re: 640 piston hydraulic pump roller bearing
Kurt-NEPA
12-09-2012 16:53:59
When I rebuilt my 660 piston pump, I put wheel bearing grease on the needle bearings, the roller bearing and little bit on the seal and shaft. Put some on the wobble shaft, thrust bearing, and plate also. Seems to have worked just fine.
The needle bearing get splash oil from engine oil coming up through the gears. The roller bearing gets oiled from the hydraulic fluid. So running lube is well addressed by the design.
