TractorLinks.com
Order Ford 640 Parts Online
Re: 640 piston hydraulic pump roller bearing
Ultradog MN
12-09-2012 16:12:11
I've never been in to one of those pumps.
But as a general rule, when it comes to bushings and bearings a bit of prelube is always a plus.
It might take a few minutes - sometimes even an hour of running to pull enough oil from the rear end up into that pump to make it prime.
A bit of grease will wash out quickly when it does prime and is cheap insurance in the meantime.
CPenn
12-09-2012 16:16:47
 Re: 640 piston hydraulic pump roller bearing in reply to Ultradog MN, 12-09-2012 16:12:11
Okay, I had some grease in it, but not like packing a front wheel bearing if you know what I mean. Is that what you had in mind? just a little grease to get by until priming?
Chad
Ultradog MN
12-09-2012 16:27:45
 Re: 640 piston hydraulic pump roller bearing in reply to CPenn, 12-09-2012 16:16:47
I generally use white lithium grease on things like that.
I would not hesitate to squeeze a teaspoon full into, onto, around and beside the bearing and race.
As long as it didn't interfere with assembly, why not?
Lube is cheap compared to hard parts.
soundguy
12-10-2012 07:41:21
 Re: 640 piston hydraulic pump roller bearing in reply to Ultradog MN, 12-09-2012 16:27:45
i agree.. I'd see no problem lubing the seals and bearings, even if they will be splash or imersed lubed later.
I pact pto beairng snad lube the selas and the entire assemble in wheel beairng grease when i R&R them... same with the ballnut and other bearings in a steering box.
i don't see how it could hurt as long as it goes back together correctly..
