Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: ford with detroit diesel
pete black
12-08-2012 12:36:37
many people could make it work, question is, can drive train handle it?
Shetland Sheepdog
12-08-2012 17:31:28
 Re: ford with detroit diesel in reply to pete black, 12-08-2012 12:36:37
If a 40 series JD can handle it (JD 435) I shouldent think it would hurt an NAA! But then what do I know?
12-08-2012 19:51:55
 Re: ford with detroit diesel in reply to Shetland Sheepdog, 12-08-2012 17:31:28
The JD 435 had a DD 2-53 rated at 30 hp.
12-09-2012 02:53:03
 Re: ford with detroit diesel in reply to Jerry/MT, 12-08-2012 19:51:55
"The JD 435 had a DD 2-53 rated at 30 hp"
You are confusing engine HP and PTO HP. Also, the 2-53 was derated with smaller injectors in the 435; an earlier Allis HD5 crawler was rated at 47 belt HP using the 2-53 with different fueling and perhaps higher compression.
12-09-2012 08:24:11
 Re: ford with detroit diesel in reply to RickB, 12-09-2012 02:53:03
The 2-53 pulled 32.91 PTO HP loafing along at 1850 RPM in the JD 435 in NE test 716, 08-18 Sep., 1959, and, yes, it was significantly derated.
The 2-53 is capable of over 50 PTO HP in similar applications.
12-08-2012 13:17:40
The better question might be wether or not the engine can handle the drivetrain...
I can think of a lot better things to do that fit a screaming, leaking, 2 cylinder vibrating gutless wonder into half decent tractor chassis.
I've often said... that 53 and 71 series detroits were the most efficient means known to man for converting diesel fuel into smoke and noise.
12-08-2012 15:19:05
 Re: ford with detroit diesel in reply to RodInNS, 12-08-2012 13:17:40
we have some 353 and 453 at work. the 353 are in old steel wheel limerock and finish rollers ( road work ).. and they are a loud bunch!
