Yesterday's Tractor Co.
Shop Now View Cart
Order Ford NAA Parts Online
Re: Jubilee 3pt won't lift
12-07-2012 17:42:24
Jay, I'm no expert on hydraulics, but your Jubilee has a suction tube
that runs from the bottom of the sump up to the bottom of the pump.
(along with a pressure tube) Those tubes have O-rings on each end.
If you have an air leak, you might want to check those O-rings, and
look for a damage or rusted tube.
12-07-2012 18:37:13
 Re: Jubilee 3pt won't lift in reply to Royse, 12-07-2012 17:42:24
Quoting Removed, click Modern View to seeOK...........
"I have not taken anything in the hyd system apart. All I did was clean out the reservoir of years of sludge and added new oil " how did you clean it if you didn't take anything apart?????? :roll:
Jay in Wa
12-07-2012 21:09:44
 Re: Jubilee 3pt won't lift in reply to JMOR, 12-07-2012 18:37:13
Originally I rebuild the transmission. When I had the tractor separated I cleaned out the hyd reservoir. I didn't take anything apart in the hyd system. Obviously you have to drain everything and take the tubes off to separate the tractor. After putting everything back together I refilled everything with new oil. The tractor sat for three years and I don't remember how well the 3 pt worked before. Anyway now I'm thinking the O rings on the hyd tubes might be the problem. However there is not even the slightest bit of an oil leak anywhere. But there seems to be air in the system from someplace.
