Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: SOS Operation question
[Return to Forum]
white halftrack
12-07-2012 11:19:05
69.80.123.107
Hello again everyone. I am working on my late 1961 SOS 971 152xxx tractor. The tractor shifts through all gears well with no problems at all, but in Park, if placed on an incline it rolls down. Is it supposed to do this or should it lock in place? It is a 312259 transmission casting and the fluid level is good filter clean. I adjusted the bands according to the manual and it still shifts everywhere fine, but no park hold. Any suggestions? Otherwise kinda liking this machine.
Thanks.
Jason
[Reply]   [No Email]
Scott Pa
12-08-2012 18:35:54
174.59.8.146
Re: SOS Operation question in reply to white halftrack, 12-07-2012 11:19:05
Try shifting quickly from 5th to park to see if it holds.
  [Reply]  [No Email]
Kly
12-08-2012 09:56:55
64.147.35.69
lock the brakes and it won't go anywhere.
  [Reply]  [No Email]
Dean
12-09-2012 10:52:32
67.172.15.77
Re: SOS Operation question in reply to Kly, 12-08-2012 09:56:55
Tough to do on the SOS tractors without brake locks.
For this very reason, I installed brake locks on my 64 4000 SOS.
Dean
  [Reply]  [No Email]
Larry NCKS
12-08-2012 11:48:29
70.195.1.88
I don't think that addresses his concern. I believe he wants a fix, not a bandaid.
  [Reply]  [No Email]
white halftrack
12-09-2012 12:08:29
69.80.123.107
Re: SOS Operation question in reply to Larry NCKS, 12-08-2012 11:48:29
Thanks for the responses everyone. I will try the 5 to P trick and
see if it works. If that does not, I will look at readjusting the
linkage. I will report back after I give it a try. It does have the
brake locks, but was afraid I was damaging it.
Jason
  [Reply]  [No Email]
Larry NCKS
12-09-2012 12:50:17
70.197.202.70
Re: SOS Operation question in reply to white halftrack, 12-09-2012 12:08:29
readjusting linkage?
  [Reply]  [No Email]
white halftrack
12-09-2012 13:03:37
174.253.148.165
Re: SOS Operation question in reply to Larry NCKS, 12-09-2012 12:50:17
The cable might not be allowing it to get fully in to park?
Jason
  [Reply]  [No Email]
Larry NCKS
12-09-2012 17:37:46
70.197.203.32
Re: SOS Operation question in reply to white halftrack, 12-09-2012 13:03:37
Possible I guess! I could feel that in the shifter if that were the case, though/
  [Reply]  [No Email]
showcrop
12-09-2012 12:42:16
75.67.231.80
  [Reply]  [No Email]
pete black
12-08-2012 12:41:45
166.205.55.37
are sos transmission tractors equipped with lockable
brakes? been a few years since i owned one but i
believe my 64 4 cylinder diesel was not equipped
with lockable brakes.
  [Reply]  [No Email]
Larry NCKS
12-08-2012 15:18:02
70.195.1.88
Re: SOS Operation question in reply to pete black, 12-08-2012 12:41:45
the early 01s were, if not all the 01s. the 4 cylinder 000s were not. I can't speak to the '65 - '74 models
  [Reply]  [No Email]
soundguy
12-08-2012 12:54:40
184.247.155.167
no pawls?
  [Reply]  [No Email]
pete black
12-08-2012 13:30:19
166.205.55.17
Re: SOS Operation question in reply to soundguy, 12-08-2012 12:54:40
now i remember, thanks.
  [Reply]  [No Email]
pete black
12-08-2012 12:41:44
166.205.55.37
  [Reply]  [No Email]
showcrop
12-07-2012 15:48:26
75.67.231.80
I use my 971 quit a lot in the summer. Before the SOS warms up, it will creep for a second or two in park, but once it gets warmed up it is pretty much instantly in.
  [Reply]  [No Email]
awhtx
12-07-2012 15:37:09
207.13.78.201
Many SOS operators have reported that the tractor will roll a bit after P is selected. The most common cure is to place the selector in 5 (IIRC) and then quickly move it to P. Fortunately I've never had this problem with either of my SOS tractors (971 & 5000).
  [Reply]  [No Email]
Larry NCKS
12-07-2012 15:34:00
70.195.1.88
B2 & B3 make Park on that machine. These are spring applied. It seems odd that all ratios work and it still rolls away in Park. Are you sure you have the proper manual? Something surely sounds off on band adjustment to me.
  [Reply]  [No Email]
Dean
12-07-2012 11:56:51
152.216.3.5
The transmission should lock the driveline when in Park though there will likely be a delay prior to engagement.
Dean
  [Reply]  [No Email]
soundguy
12-07-2012 11:34:05
184.4.146.28
here's a link to john smith's sos troubleshooting.
i'd check that first one.. as it sounds like it is going to neutral in park, assuming it is adjusted correctly and actually making it to park.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
