| Ford Tractors Discussion Forum |
Topic: 1 Test of winter heaters on 4500 this AM
[Return to Forum]
| Author |
[Modern View]
| PeteTheRookie
12-06-2012 13:34:32
74.78.16.14
 Plugged in at 8ish. Started tractor at 10. Overbite low was 25. About 28 at 8am. 30 by 10 am. Some wind. Front and top of hydro reservoir warm. Battery warm. Rad hose above heater hot, intake on water pump warm. But no flow thru to radiator. Engine took 2 crank overs to start. which is a improvement over the usual cold start. Batteries could use a trickle charge. The real test will be when its in the teens. That is when I have a real hassle getting up enough RPM"s to start it. Pete |
[Reply] [No Email] | |
| Brian in MA
12-07-2012 04:47:08
70.91.218.113
Re: 1 Test of winter heaters on 4500 this AM in reply to PeteTheRookie, 12-06-2012 13:34:32
| I have a lower hose heater on my 4000 and it normally takes about two hours plugged in when it's 10-15 degrees out to melt the snow on the hood, then she will fire on the first revolution. |
| PeteTheRookie
12-07-2012 18:25:54
74.78.16.14
Re: 1 Test of winter heaters on 4500 this AM in reply to Brian in MA, 12-07-2012 04:47:08
| Brian, So what battery are you using. As RickB pointed out half my problem is most likely too low CCA.If I leave the battery charger on it over nite. It does start a whole lot better. But as a rule I do not like to leave things plugged in unattended over nite Wish it was like my "76 Toro 724 snow blower. That has a plug in 110V starter on it. Pete |
| Brian in MA
12-10-2012 06:49:53
70.91.218.113
Re: 1 Test of winter heaters on 4500 this AM in reply to PeteTheRookie, 12-07-2012 18:25:54
| It is the biggest truck battery they had at the local Advance Auto that would fit. I don't remember the size, numbers, etc, but it isn't the 4DLT. Cranking hasn't been an issue for me. It will start without any cold weather aid down to about 35 degrees. Below that it needs a little help. |
| PeteTheRookie
12-13-2012 14:26:32
74.78.16.14
Re: 1 Test of winter heaters on 4500 this AM in reply to Brian in MA, 12-10-2012 06:49:53
| Ditto on the above freezing temp and starting. Anything 32 and above it starts. Once it gets into the 20's takes a lot of cranking. Billows cloud of white smoke.Pete |
| JF in CT
12-06-2012 14:43:57
71.88.46.81
| Are those 2 batteries in the box above the manifold? |
| PeteTheRookie
12-06-2012 15:45:38
74.78.16.14
Re: 1 Test of winter heaters on 4500 this AM in reply to JF in CT, 12-06-2012 14:43:57
| | Yes, 2 batteries. cheap ones too! PO set it up that way and it works so why fix it. Pete |
| RickB
12-07-2012 09:27:39
47.23.154.226
Re: 1 Test of winter heaters on 4500 this AM in reply to PeteTheRookie, 12-06-2012 15:45:38
| You are supplying 630 CCA's through the parallel batteries while the OEM battery would supply 810 CCA's and a whole lot more reserve. If you have issues with cranking speed, consider dumping the dual cheapie setup. |
| Wm. Neal
12-06-2012 14:36:22
38.64.150.10
| I have a battery blanket on both my 5000 and Super Dexta- both diesel), plugged in along with circulation heater for a couple of hours before starting makes a huge difference and they start with very few rev's even in -25to-30F weather. Blankets are not expensive. I have either for a quick shot (but very little) if needed.I am about 10hrs drive north of Minneapolis, where we really get winter! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
