Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: FEL removal
[Show Entire Topic]  [Return to Forum]
mick in il.
12-04-2012 15:07:15
99.21.182.146
730 loader and it's has a 3 Cyl diesel and yes I have a hoist. I need to pull it off because I'm going to do a rebuild job on it. Hope this helps. Thanks again
[Reply]   [No Email]
Ultradog MN
12-04-2012 15:39:49
184.100.109.75
 Re: FEL removal in reply to mick in il., 12-04-2012 15:07:15
Thanks for the added info.
Two hoists working together would be ideal.
You have to hold the front end of the frame up, slide it forward about 6" then dip the rear frame under the pedals and running boards, then lift them back up to clear the front axle.
We played around with one for an afternoon and gouged the pretty new paint on a 3600 trying to put it on. Clearance between the main frame and tin is Very close. We pulled it back off to fix the paint and still haven't put it back on.
[Reply]  [No Email]
TONY JACOBS
12-08-2012 06:14:34
64.12.116.9
 Re: FEL removal in reply to Ultradog MN, 12-04-2012 15:39:49
Hello Jerry , When you go to reinstall that loader on the 3600 take a CLEAN piece of rubber sheeting(at 1/4 inch thick)or thin flexible rubber mudflap from a truck with holes in the corners and tie on the tractor to protect the paint near the valve , it works great and is the only way I have been able to save the paint on tractors with the limited amount of clearence you have to work with . Thanks Tony
[Reply]  [No Email]
mick in il.
12-05-2012 04:16:58
99.103.151.177
Thanks: We were looking at it and was thinking the same thing. But my buddy says to pull off the arms and bucket and then the frame. Either way it's not going to be easy. Thanks Again for all you help.
[Reply]  [No Email]
TONY JACOBS
12-08-2012 06:23:55
64.12.116.9
 Re: FEL removal in reply to mick in il., 12-05-2012 04:16:58
Hello Mick , Remove the bucket only leave the arms on the frame , one lift, three chains, and a floor jack is all you need . One chain to the front of the frame, two the rear posts, and the floor jack under the mounting loop in the loader frame under the front end of the tractor . DRAIN THE OIL FROM THE FRAME , Disconnect the front pump and the drive shaft, pull the pins in the rear and the front bolts and lift . I do it with one of my loader/tractors by myself in about a half an hour , it is really an easy job . Thanks Tony
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
