Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 600 hydraulics
Kurt-NEPA
11-26-2012 13:44:23
If you pull that accessory plate plug with the tractor running you should be sprayed. And that is putting things mildly. If you have nothing there now, your pump is not pumping. It could be air bound, or something broke in the pump. I guess it also possible that the suction side is plugged, but somehow I doubt that. Try to prime it. If you get nothing out the pump plug, I'd pull the pump and check it out. Possible stripped gear or broken wobble shaft.
BTW, You do have a round piston pump? Right?
