Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 641 steering column bushing
kentrx1
11-18-2012 16:18:06
i removed it myself. was not much left of it, but was did have a small ball bearings in it. i posted a picture of it on this side a few days ago as i had to use a cut off tool to cut the band off. how do you get this bushing style in the column?
soundguy
11-19-2012 06:33:36
 Re: 641 steering column bushing in reply to kentrx1, 11-18-2012 16:18:06
mic the id and od.. a very slight interference fit will be ok.. VERY slight...
kentrx1
11-19-2012 07:54:24
 Re: 641 steering column bushing in reply to soundguy, 11-19-2012 06:33:36
just discovered there is still an outer hull of the original bearing shell in the column. amazing what a good nights sleep will show you.
soundguy
11-19-2012 08:39:17
 Re: 641 steering column bushing in reply to kentrx1, 11-19-2012 07:54:24
yup.. it drives in and has a lip at the top..
kentrx1
11-19-2012 10:40:04
 Re: 641 steering column bushing in reply to soundguy, 11-19-2012 08:39:17
when i use the new style bushing in the top of the shaft do i still use the spring on top of the solid bushing? do i drive the new bushing level with the column or down further?
soundguy
11-19-2012 10:54:13
 Re: 641 steering column bushing in reply to kentrx1, 11-19-2012 10:40:04
the spring is virtually useless.
old bushing had a ? 1/32 lip that sat on top edge of column.. so you could leave it 1/32 proud.. etc..
kentrx1
11-19-2012 17:25:23
 Re: 641 steering column bushing in reply to soundguy, 11-19-2012 10:54:13
thanks again soundguy! you are such a great resource!
soundguy
11-20-2012 05:01:00
 Re: 641 steering column bushing in reply to kentrx1, 11-19-2012 17:25:23
that area is one of those 'horseshoes' type measurement. ie.. generally.. if close.. it works, as that bushing just centers the top of the steering shaft. as long as the steering wheel can fit down on the splines and put the acorn nut on and it is not binding or rubbing.. should be fine.
