Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Ford 4000 4 cyl. Gas steering trouble
[Return to Forum]
Douglas Miner
11-18-2012 08:36:28
76.118.1.20
I switched the two steering lines from the column
to the ram on the side of my tractor with the
inching pedal. Now it does not want to turn. Do I
need to bleed the air out of the ram?
[Reply]   [No Email]
Sean in PA
11-26-2012 10:39:24
71.224.102.32
Re: Ford 4000 4 cyl. Gas steering trouble in reply to Douglas Miner, 11-18-2012 08:36:28
You still haven't explained what you mean by "I switched the lines".
  [Reply]  [No Email]
Douglas Miner
11-26-2012 10:49:49
76.118.1.20
Re: Ford 4000 4 cyl. Gas steering trouble in reply to Sean in PA, 11-26-2012 10:39:24
Sorry for not clarifying switched. I should have
said replaced 2 lines. I ended up bleeding the
lines at the steering ram and the steering works
fine now.
  [Reply]  [No Email]
Douglas Miner
11-26-2012 04:23:33
76.118.1.20
I switched the lines and the steering appeared to be working okay. I then topped off the reservoir and now the steering only moves a few inches then stops. I turn the wheel a little and I get a squeal from the steering pump. I tried to disconnect the steering rams but the spindles are stuck in place. Is there a trick for getting them out other than a bigger hammer? Thanks Doug
  [Reply]  [No Email]
Douglas Miner
11-25-2012 02:15:54
76.118.1.20
I switched the lines and the steering appeared to be working. I then topped of the reservoir and now the wheels only turn slightly before I get a squeal like the steering is at the end of its travel range. I tried to disconnect the front end of the rams but the spindles are stuck in place. Is there a trick for getting them out other than a bigger hammer. Thanks
  [Reply]  [No Email]
Larry NCKS
11-19-2012 05:32:32
70.198.11.5
Re: Ford 4000 4 cyl. Gas steering trouble in reply to NWMO 901 SOS, 11-18-2012 08:36:28
Now-if us lay folk only knew what "Port side" meant! :o
This post was edited by Larry NCKS at 05:33:08 11/19/12.
  [Reply]  [No Email]
Ultradog MN
11-19-2012 15:25:56
184.100.106.176
Re: Ford 4000 4 cyl. Gas steering trouble in reply to Larry NCKS, 11-19-2012 05:32:32
Sorry Larry.
If ships had inching pedals I could have helped you out as to as to the port and starboard.
  [Reply]  [No Email]
Ultradog MN
11-18-2012 18:00:52
184.100.106.176
Sean is correct. Try reversing the lines on that side and see what happens.
Do Not force the wheel against the hudraulics.
You will break the little springs in the steering actuator block in the steering column and then you'll have a bunch more questions.
Inching pedal is on the Port side of the tractor.
  [Reply]  [No Email]
Sean in PA
11-18-2012 16:55:13
71.224.102.32
Not sure what you mean by "I switched the two steering lines from the column to the ram on the side of my tractor with the inching pedal."
If you replaced them with new lines, are you sure that you hooked the same way the old ones were connected? If you reversed the connections, then the ram on the left side of the tractor will be trying to move the steering in the opposite direction as the ram on the right side and the result will be no movement.
Try disconnecting one end of each of the rams from the steering linkage and turning the wheel. That way you'll see if the rams are moving, and which way they're moving as you turn the steering wheel.
If they are hooked up correctly, then steering from full stop left to full stop right back and forth a few times should bleed any air out of the system. Have you checked the fluid level in the reservoir?
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
