TractorLinks.com
Show Parts for Model:
Re: power beyond plate
Sean in PA
11-18-2012 06:45:59
As Shaun said, you can get them here from Yesterday's Tractors. If you truly need "Power Beyond" (for powering multiple implements/control valves in series, like a loader and a backhoe), then go here for the HV5902 kit:
http://www.ytmag.com/HV5902_10670.htm
If you only need pressure and return ports for powering a single control valve setup, like a loader or a log splitter, then you can go a little cheaper with the HV4902 kit here:
http://www.ytmag.com/HV4902_10640.htm
David G
11-18-2012 16:19:03
 Re: power beyond plate in reply to Sean in PA, 11-18-2012 06:45:59
will this work on a 6610, and where does it mount?
RickB
11-19-2012 16:26:29
 Re: power beyond plate in reply to David G, 11-18-2012 16:19:03
Won't work on a 10 series 4 cylinder chassis.
RickB
11-18-2012 07:16:12
Properly done, any istallation involving a new remotely mounted spool valve should involve a Power Beyond circuit and dedicated return. The return doesn't have to go back into the plate, it can be connected to the hydraulic fill cap.
Melvin Shaw
11-18-2012 06:55:28
Thanks, I'm doing this for my dad who is doing it for a friend. I appreciate your help.
