power beyond plate
As Shaun said, you can get them here from Yesterday's Tractors. If you truly need "Power Beyond" (for powering multiple implements/control valves in series, like a loader and a backhoe), then go here for the HV5902 kit:
http://www.ytmag.com/HV5902_10670.htm
If you only need pressure and return ports for powering a single control valve setup, like a loader or a log splitter, then you can go a little cheaper with the HV4902 kit here:
http://www.ytmag.com/HV4902_10640.htm
Properly done, any istallation involving a new remotely mounted spool valve should involve a Power Beyond circuit and dedicated return. The return doesn't have to go back into the plate, it can be connected to the hydraulic fill cap.
