Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 971 carb settings
[Return to Forum]
Too Far Gone
11-17-2012 09:59:25
216.146.243.211
I recently acquired a decent old 971,rebuilding everything,having carb issues still,has inline filter which Im gonna try and remove it,an see what happens(doing crazy stuff and runs low on gas if it does start)))I rebuilt carb and I WOULD APPRECIATE IF SOMEONE COULD GIVE ME SETTINGS.Thanks
[Reply]   [No Email]
old
11-17-2012 11:36:45
209.86.226.40
 Re: 971 carb settings in reply to Too Far Gone, 11-17-2012 09:59:25
Doesn't the lit you have for rebuilding the carb have instructions???? Most kits will tell you in the instructions what the setting should be to start with. That said as per what the other guy said. As for an in line filter most of the time those cause way more problems then they ever fix
[Reply]  [No Email]
Too Far Gone
11-20-2012 20:06:49
216.146.243.211
 Re: 971 carb settings in reply to old, 11-17-2012 11:36:45
parts list only with basic instructions.It now runs great,but seems to be still running low on supply after a bit.Tossed the filter too.Think I'll just have to take carb and other attached parts off and boil again.Thanks
[Reply]  [No Email]
old
11-21-2012 08:23:02
209.86.226.57
 Re: 971 carb settings in reply to Too Far Gone, 11-20-2012 20:06:49
Befre you open the carb back up try this. Remove the carb drain plug and check for a good steady flow if gas for a few minutes. Catch the gas to look for dirt/rust etc. If you do not have a good steady flow for say 3-5 minutes work your way back to the tank to find where it is clogged
[Reply]  [No Email]
Too Far Gone
11-21-2012 15:18:34
216.146.243.211
 Re: 971 carb settings in reply to old, 11-21-2012 08:23:02
Ive got a good steady flow to carb,just got a speck inside it somewhere
[Reply]  [No Email]
old
11-21-2012 16:40:23
209.86.226.40
 Re: 971 carb settings in reply to Too Far Gone, 11-21-2012 15:18:34
Float set wrong or the needle sticking in the seat. If it is a rubber tipped needle seat then it should also have a spring clip that hooks to the float so it can not stick. Cheap kits will have the rubber tipped needle seat but not the spring
[Reply]  [No Email]
Too Far Gone
11-21-2012 16:48:36
216.146.243.211
 Re: 971 carb settings in reply to old, 11-21-2012 16:40:23
I know,I am pretty sure I forgot to put the clip on there
[Reply]  [No Email]
old
11-21-2012 16:56:39
209.86.226.27
 Re: 971 carb settings in reply to Too Far Gone, 11-21-2012 16:48:36
No clip means sticking needle seat and that gives you problems like you have now
[Reply]  [No Email]
awhtx
11-17-2012 11:12:29
207.13.78.201
Start with the 2 adjusting screws (1 on top is Idle, 1 on bottom is Load) each turned out 1.5 turns.
[Reply]  [No Email]
Too Far Gone
11-17-2012 16:52:40
216.146.243.211
 Re: 971 carb settings in reply to awhtx, 11-17-2012 11:12:29
awhtx,Thanks for answering my question.I appreciate it very much.Ive been working on both sides of 1-1/2 to 2-1/2 turns each and playing with it,but just doesnt act right all the time,part of the time its got a lot of gas in carb and then none,got fuel all the way to carb it seems,but I'll throw away the filter as Ive already read from folks on earlier posts about the inline filter problem.THANKS GUYS
[Reply]  [No Email]
soundguy
11-19-2012 08:47:31
184.233.108.145
 Re: 971 carb settings in reply to Too Far Gone, 11-17-2012 16:52:40
most add on in line filters cause flow issues.
[Reply]  [No Email]
Too Far Gone
11-19-2012 13:36:26
216.146.243.211
 Re: 971 carb settings in reply to soundguy, 11-19-2012 08:47:31
Ive got all kinds of gas running out at the carb
[Reply]  [No Email]
soundguy
11-20-2012 05:30:55
173.118.158.115
 Re: 971 carb settings in reply to Too Far Gone, 11-19-2012 13:36:26
can you be any less specific/
'at the carb'
at the fuel bowl to carb connection.
at bowl to head.. line to head.
at carb halves?
carb mouth?
out choke or throttle shaft?
[Reply]  [No Email]
Too Far Gone
11-20-2012 15:37:15
216.146.243.211
 Re: 971 carb settings in reply to soundguy, 11-20-2012 05:30:55
I could have been less specific,but you'd never have figured it out without being there,but it was exactly as stated,FUEL RIGHT UP YO THE CARB,PART TIME GAS SHOOTING OUT INTAKE PORTION OF CARB,AND PART TIME WAS BONE DRY.Got good flow all the way through NOW,got good points now,everything is great now,ended up being a combination of several things.Had GREMLINS at work!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
