| Ford Tractors Discussion Forum |
Topic: Re: fuel leaking out of choke when I try to start my 1959 fo
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Sean in PA
11-16-2012 13:51:54
71.224.102.32
First, if your starter switch is still wired the way it was originally on that tractor, then you should eb able to put the gearshift in neutral and push the start button and the starter should spin the engine no m,matter what position the key switch is in. If this is not the case, we need more information on how your starter switch is wired to be able to help.
From the title of this thread, this is a 1959 Ford, and since we're talking about the carb, and coil and spark, then it's got a gasoline engine, right? If so, then it was originally 6 volt positive ground. Is it still 6 volt positive ground? If it's been converted to 12 volt negative ground, then you'll want to be using the positive terminal of the battery for your test, not the negative.
The "High Tension" wire is that thick wire from the center of the top of the coil to the center of the top of the distributor cap. "High Tension" is another term for "High Voltage", which is what the output of the coil produces to be able to get a good strong spark. |
| Chad Batterman
11-16-2012 18:37:31
32.176.224.139
Re: fuel leaking out of choke when I try to start my 1959 fo in reply to Sean in PA, 11-16-2012 13:51:54
| Thanks for the info. It's 12 volt negative ground on a gasoline engine. Since my last post, I have solved the electrical problem by replacing all plugs, plug wires, points, condensor, and resistor. Between that and the carb work, she runs like a scalded dog. Now, on to re-soldering and pressure-testing the radiator. My thanks to Royce, Soundguy, Showcrop, Dean, and Sean in PA. for all the helpful info. Also thanks to Tom Bell at Sell Tractor Service, here in Amarillo, Texas. I couldn't have done it without you. I'll be posting any future quandries on Yesterday's Tractor Forum. You guys are the bee's knees! |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
