Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: fuel leaking out of choke when I try to start my 1959 fo
chad batterman
11-16-2012 11:48:25
This is definitely not a fuel/air problem. Thanks for setting me on the right track. I have another question, though. I am trying to diagnose an electrical problem. I, now, have no spark at any plug. My service manual tells me to connect an ammeter between the negative battery terminal and the battery terminal of the ignition coil. Turn off the ignition switch and crank the engine with the starter and observe the ammeter reading. Here's my question: Will connecting the ammeter in this way allow me to crank the starter with the ignition switch in the off position? I am a bit of a luddite when it comes to electrical issues. any help will be greately appreciated. I did, however, discover a damaged connector and missing insulation on the wire that runs from the top of the coil to the center of the distributor cap. I'll replace this momentarily. Also, my manual refers to a "high tension" wire. What do they mean by this?
