TractorLinks.com
Show Parts for Model:
Re: hydraulic valve 631
Larharm
11-16-2012 07:22:08
Thanks for you reply, will be a lot less money. right now there are two hoses about 2' from the existing valve with QD one is not in use the other goes to the cycl on the plow for vertical lift
There is only one connection for the new valve or would it have to be plumed direct to existing valve
soundguy
11-16-2012 11:30:13
 Re: hydraulic valve 631 in reply to Larharm, 11-16-2012 07:22:08
expand on that a lil.. if you only have 1 connection it may be SA.. and or there may have been a return directly to sump
Larharm
11-17-2012 07:50:17
 Re: hydraulic valve 631 in reply to soundguy, 11-16-2012 11:30:13
there is two connection but only using one for vertical lift not using one don't want down pressure on plow
soundguy
11-19-2012 06:15:54
 Re: hydraulic valve 631 in reply to Larharm, 11-17-2012 07:50:17
post a pic..
Larharm
11-19-2012 13:12:16
 Re: hydraulic valve 631 in reply to soundguy, 11-19-2012 06:15:54
hope this ok can get better pic valve tomorrow
soundguy
11-20-2012 05:29:54
 Re: hydraulic valve 631 in reply to Larharm, 11-19-2012 13:12:16
considering i was wanting to see the hyds setup.. that really doesn't help at all.
nice looking machine though.. :)
Larharm
11-20-2012 08:16:25
 Re: hydraulic valve 631 in reply to soundguy, 11-20-2012 05:29:54
These should help
soundguy
11-20-2012 10:55:27
 Re: hydraulic valve 631 in reply to Larharm, 11-20-2012 08:16:25
if only using 1 hose.. it may be setup to be single acting. / fast drop
Larharm
11-20-2012 12:00:54
 Re: hydraulic valve 631 in reply to soundguy, 11-20-2012 10:55:27
Only using one hose now i had two hose on there but did not want down pressure on the plow but it did work with two hoses
