Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 4000 Parts Online
Re: 4 cylinder gas 4000 SOS PTO
11-16-2012 06:30:58
After reviewing your post a couple times I am still not positive what your asking. Apparently you have threaded the PTO cable into the linkage collar . The linkage simply moves the valve piston in &out of the valve body routing Hyd. Fluid. Should work freely , engine running or not. You should be able to easily activate the linkage thru its range of motion with your fingers. If the linkage is not stuck or broken,then the valve piston is probably stuck. Best done with the proper manual at hand, remove the top of valve body and R&R all valve spindles.
