TractorLinks.com
Show Parts for Model:
Re: fuel leaking out of choke when I try to start my 1959 fo
chad batterman
11-16-2012 03:36:41
Royce, when you say "these really don"t really go together at startup" what do you mean by "these". I checked for spark by pulling the spark plugs individually, held them close to a ground point,and cranked the starter. The spark is bright blue-white on every plug. Is there a better way to check for spark at the plugs? (With the air-breather hooked up) When I have gotten the engine to start, it runs great at low idle. The engine sputters and dies at 2/3 to 3/4 throttle, and the once-clean plugs are, again, fuel fouled. could this be a distributor issue, and not a fuel issue. I"m beginning to think thet the once-suspect carb may not be the culprit. Thanks for your reply.
