Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: fuel leaking out of choke when I try to start my 1959 fo
Royse
11-15-2012 18:39:34
These don't really go together at startup, unless you're really way over doing the choke.
If it's been flooded that many times, I would try new plugs.
What do you mean when you say "good spark"? Bright white spark?
How/where are you checking the spark?
Flooding while running - with or without the air breather hooked up?
chad batterman
11-16-2012 03:36:41
 Re: fuel leaking out of choke when I try to start my 1959 fo in reply to Royse, 11-15-2012 18:39:34
Royce, when you say "these really don"t really go together at startup" what do you mean by "these". I checked for spark by pulling the spark plugs individually, held them close to a ground point,and cranked the starter. The spark is bright blue-white on every plug. Is there a better way to check for spark at the plugs? (With the air-breather hooked up) When I have gotten the engine to start, it runs great at low idle. The engine sputters and dies at 2/3 to 3/4 throttle, and the once-clean plugs are, again, fuel fouled. could this be a distributor issue, and not a fuel issue. I"m beginning to think thet the once-suspect carb may not be the culprit. Thanks for your reply.
