Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: fuel leaking out of choke when I try to start my 1959 for...
chad batterman
11-15-2012 16:31:13
The carb is actually a tsx 813. The relief flap opens inward and seems to be working. Could anything else cause this problem?
soundguy
11-15-2012 16:47:21
 Re: fuel leaking out of choke when I try to start my 1959 for... in reply to chad batterman, 11-15-2012 16:31:13
is it leaking constantly.. or only when choked?.
chad batterman
11-15-2012 17:19:18
 Re: fuel leaking out of choke when I try to start my 1959 for... in reply to soundguy, 11-15-2012 16:47:21
It only leaks when choked.
Dean
11-15-2012 18:10:49
 Re: fuel leaking out of choke when I try to start my 1959 for... in reply to chad batterman, 11-15-2012 17:19:18
The engine is badly flooded.
Sandblast or replace the plugs.
If all else is well, it should start.
Dean
chad batterman
11-15-2012 18:29:36
 Re: fuel leaking out of choke when I try to start my 1959 for... in reply to Dean, 11-15-2012 18:10:49
Dean, I've cleaned and gapped the plugs a few times over the past week. I have recently been able to get it started, and it runs well at low idle. The engine starts to roll and dies at 3/4 throttle. This has been the case the four times that I've managed to start it. The low idle screw is out one turn. I've tried again with the high idle out 2 turns, as my tractor mechanic suggested, and also out 1 1/4 turns as the manual suggests with no success. Once it dies, I have only been able to restart after cleaning the badly fuel-fouled plugs. HELP:)
soundguy
11-16-2012 11:32:27
 Re: fuel leaking out of choke when I try to start my 1959 for... in reply to chad batterman, 11-15-2012 18:29:36
it's flooding out then...
soundguy
11-15-2012 17:23:48
perfectly normal.
when you choke it is sucks a spray of fuel thru.. it has to go somewhere...
