Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Ford 7710 remote hyraulics
11-15-2012 12:04:21
At least one of them must be worn out, because it keeps popping out while I'm using the tractor.
What do you have to buy to change it to the newer leverless style? The present couplers are part of the whole unit. I can replace just the coupler buy taking the unit apart. The couplers were about $100 each the last time I checked, but then I would still have the the lever type couplers if I did this.
11-15-2012 13:49:25
 Re: Ford 7710 remote hyraulics in reply to gleanerguy, 11-15-2012 12:04:21
Pop the rubbers off the end and you should see the ball ring/sleeve of the coupler. The sleeve/barrell will just thread out. There's a tool to loosen them but it's nothing a good pin punch won't do if you're carefull. I don't remember now if you need to remove the lever and it's shaft firs or the barrell will come out anyway... but you need to remove the lever at some point. Then you're left with the bare aluminum housing. All coupler kits now available for the Rexroth valves are leverless. They provide a kit with the new coupler barrells and covers to go over the holes where the levers used to be... but I never had any luck keeping them in place. Just renew the seals in the body and thread the new couplers in. Done.
As Bern said... they do leak a bit at times but that's typical of most quick couplers.
11-15-2012 13:29:39
Tell us more about this "dealer engineered unit" (pics would be nice). It sounds to me like you are complaining about something that Ford never put on.
The factory valves sometimes like to leak, but otherwise they worked pretty well.
11-16-2012 13:52:10
 Re: Ford 7710 remote hyraulics in reply to Bern, 11-15-2012 13:29:39
It is a the standard unit put on most 7710's. It is not an aftermarket unit. It is obvious that Rod understands what I am talking about. The fellow that posted about his 8700 doesn't understand, because that is a totally different system.
I understand that there may be a leverless unit available. I don't know if some had the leverless unit from the factory or if that was something that you could buy to upgrade. I am going to see my dealer this afternoon. He is the one that referred to this as an "engineered unit". I would rather spend money on an upgraded unit than spend $400 plus to buy four new couplers for this unit.
11-16-2012 19:23:47
 Re: Ford 7710 remote hyraulics in reply to gleanerguy, 11-16-2012 13:52:10
The leverless couplers were simply a point in time change that came along in the mid 90"s... perhaps when they realized the problems with the lever type couplers as they aged. As far as I know you can"t get the barrells for the lever type any more.
11-16-2012 18:13:12
OK, I misunderstood your first post.
The factory remote valves for those tractors were overall good units. I would not discard them. Check to make sure the threaded coupler on the end did not screw out.
