auxiliary engine recirculating water heater.
Anonymous-0
this pump heater is externally from the engine. heater procured at tractor supply company. directions state connect lower inlet to below the water jacket p-lug. I have that. I am having a difficulty as to where to connect the upper port back into the engine. Is it necessary to remove the fuel injector lines going to the injectors to access what might be where it is to be connected?
