TractorLinks.com
Order Ford 640 Parts Online
Re: 640 temp sensor replacement:how do you get the new one 2 sea
awhtx
11-10-2012 16:17:28
The only way you will ever get the nut tight enough to completely seat the sensing bulb is to use a flare nut wrench (tubing wrench, line wrench, whatever you call it) to tighten it. You will surely round off the corners of the nut if you use a open end wrench. I have had to remove the battery box in order to get a good grip on the nut. I have contemplated taking a 5/8" deep impact socket and cutting a slot in the side of it for the capillary tube to pass through and trying to tighten the nut with that but I've never got around to making it.
soundguy
11-10-2012 16:27:24
 Re: 640 temp sensor replacement:how do you get the new one 2 sea in reply to awhtx, 11-10-2012 16:17:28
wonder if an O2 sensor socket would fit?
John in La
11-11-2012 00:29:20
 Re: 640 temp sensor replacement:how do you get the new one 2 sea in reply to soundguy, 11-10-2012 16:27:24
I think a O2 socket is 7/8 he needs 5/8.
Finding a injector socket in 5/8 would be a task also.
I would think a flare nut crows foot in 6 point would work.
soundguy
11-12-2012 06:07:25
 Re: 640 temp sensor replacement:how do you get the new one 2 sea in reply to John in La, 11-11-2012 00:29:20
yep.. yer right.
I have a 7 pc sender changer kit and was thinking it had 1 other size in it.. .. and it does.. it's a bigger size for some oil senders. it has a couple pieces that essentially look like a crows foot socket adapeter versio of a flare wrench.. so you may be on to something there. :)
