| Ford Tractors Discussion Forum |
Topic: Re: steering box side cover on 641
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| soundguy
11-10-2012 15:56:05
173.107.64.138
 have you got the sector arms off? they have to come off the adjusters are studs in a slip fitting on the sector the sector gear and cover exit out the same path.. which is why the sector arms must be off the other side. i've marked up a drawing of the steering box on a 640 the side covers have a lip inside .. it may be siezed a pit. tap on the ears to rotate them and get themmoving. penetrant will help.. just pull them and the adjusters togeter dragging the secrtor gear out. if they are seized it will be the easiest way.. |
[Reply] [No Email] | |
| kentrx1
11-10-2012 16:37:23
98.26.128.209
Re: steering box side cover on 641 in reply to soundguy, 11-10-2012 15:56:05
| i was under the impression i could just pull the sector gear out a little and leave the sector arms on and that would allow the center shaft to be removed giving me access to the lower thrust bearing and room to clean out the bottom of the box. the seals on the sector shafts do not appear to be leaking any and i don't plan on replacing them. please correct me if i am wrong! thanks again. |
| Keith Williams
11-11-2012 05:38:37
24.142.137.38
Re: steering box side cover on 641 in reply to kentrx1, 11-10-2012 16:37:23
| | kentrx1 "the seals on the sector shafts do not appear to be leaking any" Hate to tell ya this but they are not leaking cause there wasn't any lube in there! Those seals are what goes first. Then the lube comes out. Then the bearings go!! A few wash jobs and any trace of the old lube is long gone. HTH Keith |
| kentrx1
11-11-2012 11:47:03
72.149.185.59
Re: steering box side cover on 641 in reply to Keith Williams, 11-11-2012 05:38:37
| it had quite a bit of oil in the box actually. was probably 90 weight and very dirty with some water mixed in, but was not empty. no sign of leaks at side seals....they were both dry. |
| soundguy
11-10-2012 17:18:41
173.107.64.138
| | you might cheat both sector gears out enough to pull the ballnut assy.. however you are 95% of the way there doing so.. why not just pull them? i thik your course of action will turn a routine rebuild job into a hard one.. your call. I've rebuilt many of these boxes.... generally not difficult.. about the biggest issue is sometimes cheap chinese bearing cages that crumble.. OE.. ballnut assy that are soo worn the ballut cocks to the side.. or sector gear teeth profiles that wear to a point.. etc. broken adjuster stud holder ears.. etc.. stuff like that. otherwise they are pretty bulletproof. and straight forward to service |
| kentrx1
11-10-2012 17:28:32
98.26.128.209
Re: steering box side cover on 641 in reply to soundguy, 11-10-2012 17:18:41
| thanks soundguy. your help is much appreciated! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
