TractorLinks.com
Show Parts for Model:
Re: 850-Cold wearther and tractor hydraulics ?
JMOR
11-10-2012 06:20:33
If not leaking externally, then if it is leaving hydraulic section, then you should see a rise in the transmission &/or differential compartments. Rise?
And yes, lift piston in under very little pressure with no weight on lift.....piston pressure is proportional to weight being lifted/supported & that is by no means the direct pump maximum pressure unless weight is up at maximum, around 1200 pounds.
This post was edited by JMOR at 06:23:45 11/10/12.
Billy NY
11-10-2012 07:08:59
 Re: 850-Cold wearther and tractor hydraulics ? in reply to JMOR, 11-10-2012 06:20:33
2nd part makes sense, when I switch over from the 2 bottom to the counterweight, I'll take off the filler cap and see again, just cannot recall if I did it with weight on, which is a heavy cast iron, alleged ford aircraft tug weight, has to be well over 500 lbs but under 1000lbs, hard to estimate what it weighs, heres a photo well no photo what the heck happened to photobucket, can't copy the link, they changed the page oh well
