| Ford Tractors Discussion Forum |
Topic: NAA electric question..
[Return to Forum]
| Author |
[Modern View]
| upnorthwi
11-09-2012 18:50:40
76.2.221.25
1954 NAA 6 voltJust noticed on the new NAA that when you pull the headlight switch it instantly kills the tractor. Any ideas and where do I start looking first? Thanks |
| 36 coupe
11-16-2012 03:35:40
66.186.169.176
Re: NAA electric question.. in reply to upnorthwi, 11-09-2012 18:50:40
| Headlite switch should have a fuse on it.No fuse, a short in the headlite wiring would kill the engine when you turn on the lites. |
| soundguy
11-10-2012 15:19:08
184.247.43.180
| | my guess is your headlamps are run thru the ignition switch and it's not up for it / has a bad connection. offload them from the ignition.. let it just handle the coil, and exciting the alternator if it has one.. :) source power for the lamps on the same side of the ammeter as the ignition switch is drawing from to preserve your net charge / discharge setup |
| Sean in PA
11-10-2012 03:39:29
71.224.102.32
Re: NAA electric question.. in reply to Larry NCKS, 11-09-2012 18:50:40
| Quoting Removed, click Modern View to see
Or a dead short to ground somewhere between the headlight switch and the lights themselves. I would disconnect the battery and do some testing with a meter. You don't want to keep draining the battery with a short like that if that is the problem.
Disconnect the wire at the headlight end and with the switch off, measure resistance from the headlight end of the wire to ground. Should be infinite resistance. If it shows any resistance below infinite then you've got a short to ground somewhere between the switch and the headlights (or inside the switch itself).
Then with the wire still disconnected, measure the resistance from the switch to the headlight end of the wire. That should read close to zero ohms. Anything more that a couple tenths of an ohm and there's a problem with the wire like corrosion, rust, dirt or a loose connection somewhere. |
| JMOR
11-09-2012 19:50:06
72.181.173.171
Re: NAA electric question.. in reply to FordTractorMan, 11-09-2012 18:50:40
| Quoting Removed, click Modern View to seeCheck for bad/weak connections, most likely in the path between the lights and the battery, including battery ground. i.e., some connection is good enough to carry ignition current alone, but not good enough to carry ignition plus lighting current. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
